    Sep 2003
    cape coral
    I have the JVC sa70bk and I want to know if memorex dvd+r will be read by this dvd player. I have a nec 1100 dvd+ burner. I really need help with this. Thanks for any help available. Links would be great.
  2. I had a similar problem with my Mintek 1600 not reading DVD+R's try this
    I learned that I have to use nero in non- wizard mode
    select dvd video mode on the left- tick ISO LEVEL ,1 tick ISO 960O uncheck everyting else, and then the resulting DVD+R will play your player..
  3. Memorex DVD+R media should have RICOHJPNR code wich is good media.
    As far as I know the Nec 1100 writes DVD-ROM booktype to DVD+R media by default for maximum compatibility.
    So if you use the proper setting in a burning program I believe there's a great chance that those discs will be playable.
    Some great Nero guides can be found here
    http://www.dvdshrink.info/nero-video.php
    http://www.dvdshrink.info/nero-udf-iso.php
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
    Sep 2003
    cape coral
    Thanks for the advice. I have the program sonic mydvd. Will that work or does it have to be nero? I am a newbie at this.
  5. SonicMyDVD is for capturing home movies to DVD/VCD.
    If you want to backup your DVD movies I suggest DVDShrink (free)
    and a burning program (there are freewares, trialwares)
    Try to do a forum search.
    Sep 2003
    cape coral
    Know I like to download clips or movies off the internet and burn them. I'll download the free version of nero until my broke ass can get some money.
