    I dont know if i can be asking this here but i back up one of my movies to divx. My video is a lower frame rate than my audio and i dont know how to fix this. This is preventing me from syncing them. Any suggestions ?
  2. So I take it you are getting a gradual loss of sync correct? So the sound near the end of the movie is off by a greater amount the the beginning?
    Here is a guide to fix that
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
    The best that i have been able to do is the beginning would be correct and the end would in sync. Everything else in the middle would not be.
    in the beginning the movie is at 30fps and the video is at 24fps throws it off by 20 minutes. Ive encoded several other movies and have not had this problem this is the first one.
