I have been looking high and low for something to encode video to a HDTV mpeg2 stream but have not come up with anything.
Is there any software encoders that can create a HDTV compatible video stream???
Or is there a way to force tmpegenc to do it???
I have tried almost everything i know. Adobe premiere pro 7 with mpeg2 encoding just resizes the video to 720x480. Tmpegenc just says the size is wrong and i had a guy at work try with there copy of cleaner xl and he couldn't change the mpeg2 res.
Thanx
Results 1 to 17 of 17
tmpgenc can do it fine - but the quality is only so so (not to bad)
main concept can do it fine also ..
canopus procorder can also do it ..
Vegas can also do it (uses main concept encoder)
Blade can do it (uses tmpgenc encoder engine)
Premiere can do it (6.5 and Pro (7))
high end HD encoders are much higher in price (MUCH!)
you use different matrix and gop settings completly ..
remember for HD you have to set Main profile and High Level or higher in profile and Level settings .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
cleaner (any version) sucks at both speed and quality (awefull program)
squeeze I think can also do it -- squeeze has much better quality than cleaner (uses main concept encoder again - as does adobe above)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
how hd is hdtv 1920x1280 perhaps? what sort of bitrate does that require 3000 min 50000 max
mpeg2 HD can go to 118meg/s bit rate -- and higher ..
depends on what you are going to play it back on ..
broadcast HDTV is 19.4 meg/s bit rate
HD playback servers for the most part top out at either 34meg/s or 50meg/s
the above for 1080p (i dont like 1080i) ...
almost all HDTV streams are ac3 audio and transport streams .. transport stream multiplexers are rare and expensive , i use manzanita multiplexers .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i am trying with tmpgenc and cannot get it to work, it keeps saying "window size is not accepted", It will encode the 1280x720 with mpeg1 but not mpeg2.
Mainconcept will not let me go to 1280x720, will max the res out at 720x480.
Adobe premiere uses mainconcept for mpeg2 output and is therefore also restricted to 720x480 (actually true ntsc so 720x540 with non-square pixels). ( I know this because i outputed a file with the project settings to the res of 1280x720 and the output mpeg was still 720x540)
nothing seems to be able to export true hd res with mpeg2, only mpeg1.
There versions of the programs i have used are as follows
mainconcept 1.03.01.00
tmpeg 2.511.51.160 / 2.520.54.163
Is there something i am doing wrong?? -
yes -- you didn't read my thread above completly is what you are doing wrong ..
check the level and profile comment above ..
but adobe 6.5 i now seem to recall might not be able to do HD directly but only to the stand alone MC encoder via frame serving .. though i would not use adobe premiere for HD work (After Effects yes though) .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Sorry i didn't understand, i just needed to look more carefully, then i noticed what you were saying, but the option for high level was not availble. That was with a newer free tmpg i dled, so i went back to my plus version and there it was
Thank you muchly -
I can understand them being rare, but expensive ? The transport stream is just a bit different from the program stream. Mainconcept can encode to transport stream directly, although I suppose one would want to multiplex more content into the transport stream.Originally Posted by BJ_MThe more I learn, the more I come to realize how little it is I know.
yes it will - but it is a USELESS transport stream as standalone HD servers dont decode mpeg audio (which is the output of the MC encoder) , plus its not that hot a transport stream anyway .. there a LOT of settings ina transport stream which are pretty importaint for broadcast (low end HDTV) on up ... thats why the multiplexers are 2000$ on up to do this correctly ..Originally Posted by SaSi"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Does that hold the logo and other station specific info?Originally Posted by BJ_M
windvd will properly decode HDmpeg files - though it will report the max bit of only 15meg/s (just ignore it)
media player sucks in general for mpeg anything .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
nopeOriginally Posted by Faceman101"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Heuris makes a very good HD-MPEG encoder as well. As usual, it's $$$.
Don't worry, this is one of those things that will soon (1-3 years?) be taking the downward price slide. It's in the cards, be patient.
MPEG2 TS HDTV to H264
By Dr_Layne in forum DVB / IPTVReplies: 3Last Post: 30th Aug 2009, 17:08 -
Best way to convert mpeg2 .ts 1920x1080i HDTV to AVCHD?
By Dr_Layne in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2009, 01:46 -
how to play high definition mpeg2 on HDTV
By edong in forum Newbie / General discussionsReplies: 4Last Post: 11th Mar 2008, 11:49 -
HDTV MPEG2 to AVISynth to FAVC help?
By Valnar in forum Video ConversionReplies: 18Last Post: 5th Nov 2007, 05:15 -
best free mpeg2 encoder for me!!!
By malahal in forum Video ConversionReplies: 10Last Post: 9th May 2007, 12:18
