Okay, it's out. But I haven't been able to find many reviews. Is it worth the extra $$$ over other capturing and writing software? I don't have a capture card, but I do have a fairly fast CPU (Athlon 2500) and a gig of memory...and a 160 gig drive.
I know there's a ton of cheaper programs out there. I want something that's fairly easy to learn and easy to edit out the junk I don't need. But I want quality encoders and possibly something else I can throw on my resume. I'll be going from mini-DVD to DVD and want as good a quality as I can get. I hear Premiere has real time capture and great tools.
Any advice?
Thanks!
John
"If at first you don't secede, try, try again!"
Premiere doesn't capture or write. It's a video editor.
well it can capture .. but yes -- its a editor formost and any capturing would be DV which is not a factor in what you capture with - or hardware specific ..
Premiere would look good on a resume. Avid would look good on a resume too.
That said I won't buy either. Maybe think about Vegas Video. Alot of people are starting to use it instead of the others. Personally I use EditStudio from puremotion. Easy to use, great results, cheaper than many others for what it does (can do). Now has an sdk to interface with third party 3D effects software. Free 30 day demo. Mpeg pluggin for encoding based on the MainConcept encoder. Does a wonderful job for me with DV files. New version says it will work with mpeg files too, but I haven't upgraded yet.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Premiere Pro 2 Help
By slicebogey in forum EditingReplies: 6Last Post: 9th May 2011, 18:21 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 23:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 18:10
