I have windows media player 9 installed on a computer here at work and when I try to play a .mpg file... it won't play it. I thought version 9 would be able to play that type of file without a problem. Do I need something else. Do I need to install a codec for it?
_
you need to a install a mpeg2 codec for that bad media player 9 ... install powerdvd or windvd ..
I installed a mpeg2 codec and now it doesn't kick it out but there is no video, just a black screen. I didn't think it would be this hard to play a .mpg in WMP.
Which MPEG2 codec did you install, not all of them are created equal. I would suggest that you d/load the Power DVD demo, install it, then un-install it the (the MPEG2 codec will not be uninstalled).
WMP 9 absolutely sucks for playing MPEG's. Try the WMP classic 6.4.x.x , it's a single file standalone you can put anywhere ( including replacing the old original mplayer2.exe file.....like I use to hide at work).
To Be, Or, Not To Be, That, Is The Gazorgan Plan
wmp win7 not playing certain mpeg1 files, gspot info included
By Rudyard in forum Software PlayingReplies: 6Last Post: 7th Jan 2011, 02:53 -
Streaming MPEG2-TS files to WMP 11 (XP)
By Penumbra in forum Video Streaming DownloadingReplies: 0Last Post: 2nd Apr 2010, 16:39 -
How to delete music files from WMP Playing List
By usta in forum Software PlayingReplies: 0Last Post: 25th Jun 2009, 09:28 -
No Sound When playing MKV files in wmp or media player classic
By tmiller_15 in forum Blu-ray RippingReplies: 2Last Post: 12th Jun 2009, 23:24 -
Playing flv files with WMP
By INFRATOM in forum Software PlayingReplies: 1Last Post: 22nd Jan 2009, 03:12
