Results 1 to 9 of 9
  1. Member kpoman's Avatar
    Jan 2003
    Ok, I want to convert an avi (890,528 KB) to a SINGLE disk VCD. I know I need to convert this file to an MPEG and I want to use Tmpeg but what setting do I use to ensure that this file will not be too large for a single VCD? Thanks in advance for the help.
    Live Long, Play Hard, Think BIG!
  2. there´s a guide in the guides section on how to do that....look for "how to make a xvcd"
  3. Member kpoman's Avatar
    Jan 2003
    The only guide I found contained instructions on how to make 2 VCD's. I only want (1). I'll keep looking. Thanks
  4. quality will be awful, but if you dont have another cd to spare...
  5. quality will be awful, but if your DVD player wont support SVCD/CVD, and you dont have another cd to spare...
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  6. Use KVCD 352x240 PLUS templates. They have almost the same quality as VCD (not noticable difference), but can fit up to 2 hours of video on one CD. The length of video you can fit on one CD usually differs with the kind of file you have, but it will for sure be greater then 1h 20m (VCD).
  7. Member kpoman's Avatar
    Jan 2003
    Yea, quality will be awful but I just wanted to see if I can do it. Thanks for pointing me in the right direction Baldrick!
    antonv: Thanks for your help on the templates. I will give them a try as well.
    This site rocks!
  8. Member Conquest10's Avatar
    Chicago, IL
    also, try learning a bit about avisynth. avisynth in conjuntion with kvcd templates yield great results.
    His name was MackemX
