I want to convert an asf video to mpg (I think I have to convert to avi first, then to mpg).
I have been trying to use "AsfTools 3.1", but when I try to convert to avi, the resulting file will not display video - I only get audio.
Is there a way to do this correctly, or am I just screwed??
doom9.org has a great tool to do this. Converts the ASF back to AVI video. Downside is it won't do DRM material. I think we have it on this site as well.
Do you have the latest version? Some of the new WME9 codecs aren't supported in older versions.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Digital Rights Material
If it has the 'copyrighted' bit set, it won't let you convert it, even if you own the rights to it. This is to avoid being sued by M$. That way you can't take the HD version of some new DVD's( you do know that there are WMV's on some DVD's, like Terminator 2, now in HD resolution, although what you are supposed to do with them...) and convert the WMV to a HD version in say....DivX.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
You can also try TMPEG, I've had some luck converting to MPG from ASF.
Dower -
Failing tmpgenc convert it to wmv with windows movie maker then tmpgenc will accpet it. I have had to do this before and it works fine.
asf to MPG conversion
By kshavo in forum Video ConversionReplies: 1Last Post: 15th Oct 2010, 05:14 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 11:07
