I bought a VCD (recorded on a CD-R) from a seller on eBay and neither my CDROM nor my DVDROM drive will recognize the disc. When I try to run PowerDVD I get the message "unsupported disc format." I've tried the disc on multiple machines running different OSes (98, XP, NT, 2K), but with the same result.
I have some other VCDs from other sellers/traders and they work fine on my PC (both drives), so I think my drives are not the problem.
The seller claims that the disc works fine on his machine and DVD player, which adds to the confusion. Is it possible the discs are authored incorrectly? Could it be a problem with the media?
Any ideas or suggestions would be greatly appreciated.
Mike
Thanks for your response. The problem is, my CD-ROM and DVD-ROM drives can't even read the disc. I get the message: "Not Accessible. Incorrect Function." when I tried to view the disc with Explorer...
I would suggest that you try this disc in another machine with a different configuration (different drives, motherboard, etc.) perhaps a friend's. If it doesn't work on a different machine, you should return the disc and ask for a refund, the disc is unreadable and therefore defective.
If it was a problem just playing the disc, I would'nt be so quick to judge, buit if the disc cannot even be RECOGNIZED by more than one machine, it is definitely bad.
Prospero -
Originally Posted by Prospero424
I told the seller of the problem, and he made, tested, and sent another disc, yet the disc still has the same problem... And since he claims he tested the disc, I can't get a refund...
I'm not pissed, but disappointed by all this... Anybody else have any sage words of wisdom??? -
Addendum:
While that damn VCD/CDR disc still will not play on any of my PC equipment, it actually plays on my brother's Sony DVD player, which is about a year old. Go figure.
I guess I have to buy a new DVD player just to support this (and maybe future) VCDs/CDRs... Groan.
Playing NTSC on PAL DVDRom?
By th3obr0 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Feb 2009, 23:18 -
Classic Arcade Games CDROM restarts PC?
By rijir2001 in forum ComputerReplies: 5Last Post: 9th Apr 2008, 23:33 -
Archiving DV.avi to DVDROM
By dgpretzel in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 13:53 -
directly connect my cdrom/dvdrom to tv
By d_unbeliever in forum ComputerReplies: 2Last Post: 1st Mar 2008, 03:02 -
CDROM that burns commercial media
By Krispy Kritter in forum MediaReplies: 6Last Post: 19th Dec 2007, 09:30
