    Aug 2003
    Melbourne, Australia
    To all in DVD world:
    Currently, I author VCDs using the typical VCD menu structure.
    Is it possible, using DVD authoring software, to create DVD type menus, with DVD style interactivity, and burn in onto a CD? Does DVD authoring software, (and indeed DVD players) rely on the actual DVD media to function?
    Looking forward to any feedback. Cheers-
    Elio.
  2. Try Ulead DVD movie factory. You can make svcd's and vcd's with dvd type menu system. You could download the trial version and give it a try.
    No, you can't have same dvd interactivity menus on a vcd. But you accomplish almost the same, https://www.videohelp.com/author#27
    You can burn dvd on cdr/w media though but then it will be minidvd/cdvd and it doesn't work on many players. www.dvdrhelp.com/minidvd
  4. I believe adam's guide here. Takes DVD like vcd/svcd menus to the limit.
    The concept is simple, if anything changes, you are looking at a new menu/video clip. Basically, if you want to mimic highlights, draw a new picture and switch to that. Motion menus are the same.
    All of this is really a lot of trouble to create (even if some package does the heavy work for you).
    I mean it in the nicest way.
    Aug 2003
    Thanks for the replies guys. I'll visit the suggested links.
    Cheers - Elio.
