I have a divx movie that wont play in media player. Gspot says the file is truncated? Someone told me to try video lan. I tried that and it works, yay. But i want to convert it to vcd and tmpge wont let me. I get this box saying "index of scan line is out of range(256)". Anyone have a clue wut I can do
Can you open it with VirtualDub?
If so you could try checking for errors, then saving out as a new AVI.
You could also try frameserving to TMPGEnc from VDub -
It's corrupted. You have to fix it before it will play(use VDUB). Actually it sounds like it's not finished downloading.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
K well i opened it with vdub and figuered out how to frameserve. Well it did finish dl'ing according to BT. How do I fix it with vdub.
could also try divfix
when you go to convert to ensure that you dont have additional problems (you probably will with the type of video you downloaded). Download a copy of the divx codec pack and also the xvid codec.
After installing those, use dvd2svcd to convert to vcd,cvd,svcd, or dvd.
Sony DVP-SR750H wont play divx files.
By dupsko21 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 9th Mar 2012, 19:35 -
AVI with DTS wont play - can I convert?
By snadge in forum AudioReplies: 4Last Post: 29th Jul 2009, 09:41 -
help tvix 6500 wont play true hd how do i convert
By lodwales in forum Authoring (Blu-ray)Replies: 5Last Post: 21st Mar 2009, 07:45 -
AVI wont play on standalone player, need to convert to what
By haubmi in forum Video ConversionReplies: 13Last Post: 10th Mar 2009, 13:58 -
wmv file wont play nor convert
By excitezone in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2007, 12:56
