  1. ive done this many times before, but im trying to merge and cut 3 scvd discs together... all are fine, but after the merge everything after disc 1 is way out of sync as far as audio goes.. by minutes, not seconds...
    any ideas on what i can do.. theres no error codes or anything. ive tried it
    with vcd automatic, vcd, and super vcd settings..
    thanks
  2. Each of the MPEGs played correctly before merging?
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  3. yeah...
    thats the weird part...
    ive done it 3 times already with no luck...
    im stumped
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    What do you use to merge? (I've never had much success either)? TMPGEnc claims to be able to merge mpegs made with TMPGEnc, nothing else.
    There's a command line tool, mpgtx, that can cut and join mpegs, but I've yet to try it out.
    /Mats
  5. i use mpg tools in tmpgenc....
    ive had great success in the past....
    i think ill just have to author each individually and combine them in dvd shrink....
    there will be a pause between when going to the next disc and the chapters will start over, but it'll be on one dvdr....
    any other ideas why it has done this?
