I've had a dvd burner for a couple months and I just got a new computer. I put my Pioneer DVR-A05 in my new dell and it won't work correctly. It's a 4x burner and it burns inconsistantly from .5x to 1.7x. I've tried changing it from master to slave and switching it in a different slot. I checked the driver info and it says its a microsoft generic driver. I looked on my instillation disc and i dont think the driver is on there. The burner worked fine in my sisters computer which is almost the exact same computer, a new dell w/ win xp. Could it be the driver or does anyone have any idea of whats wrong?
Thanks,
Adam
Ya, it says use dma if available. Is there anything else it could be?
Thanks,
Adam -
remove the device from windows control panel (don't just disable), shutdown, then remove the A05 cable itself. reboot the machine and do another shutdown. reconnect the cable (it doesn't matter if it's master, slave or primary or secondary channel) and turn on. The device should be reinstalled automatically. Look in device properties once it has loaded the driver and check that it is using DMA. IF not, then you BIOS is your PC may be incorrectly setup...
I had two problem just like this it seem that PC that are made for you like DELL and HP can be a pain to install new hardware. my PC I built it my self never had a problem getting any thing working. I would call dell there might be a setting you have to change.
First. look on the back of the drive to see the position of the jumper pin. If it is set to MASTER you MUST use the 1st (middle) connector on the cable. For SLAVE the Last (end) Connector. Don't use the CS (cable select) On start up, enter bios and click on IDE Auto Select, It will recognize the drive. Click save and exit.
Windows will install the drivers (XP-2000) and you should be ready to go. If you still have a problem you are probably using the wrong cable to connect ie 40 pin instead of 80 pin. I use gold anodised Ultra DMA cables Not really expensive but soft, handle gently.
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 09:24 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20
