Does anyone know which authoring program can import VOBs (and AC3, if it has to be imported separate)?
What I have is different vobs that are multiple titles, each title with their own chapters, and I don't need or want to convert and lose quality. And I want a DVD that'll use the chapter buttons to advance chapters, and title button or menu to switch between titles.
Best method I've read about so far is just to make the 2nd title the chapter after the last chapter of the 1st title. But then the titles would have to be in sequence, and this method doesn't use menus so I'd have to chapter through just to get to the next title.
I'm hoping there's something better.
try tmpgenc dvd author.
Its the easiest I have used & can import vob files. the latest vers also has more menu options. -
That was my first guess, but I had trouble importing audio. Wouldn't accept vob or ac3 audio files. Is there some option somewhere, or do I have to use a separtae program to convert the ac3 first?
Oops! Nevermind. I was using tmpenc plus (which can encode to DVD), not the DVD author tool. will try author tool now, thanx
I'm having great luck with ULEAD's MediaStudio Pro 7.0, which includes an AC-3 enabled version of Ulead DVD MovieFactory 2...Originally Posted by kita
http://www.ulead.com/msp/features.htm
...this "LE" version of Ulead DVD MovieFactory 2 can import/edit AC-3 MPEGs.
Jerry Jones
http://www.jonesgroup.net
Capture video straight to DVD (for MAC)
By eutapio in forum MacReplies: 11Last Post: 29th Apr 2011, 16:19 -
Why doesnt my DVD go straight to MENU FIRST???
By SeeNoEVO in forum Authoring (DVD)Replies: 15Last Post: 25th Mar 2009, 13:56 -
Straight Burn to DVD
By lookingtoburn in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2009, 19:22 -
Do you install software from the cd/dvd or go straight to the website?
By yoda313 in forum PollsReplies: 11Last Post: 18th Jun 2008, 15:10 -
Authoring a DVD - trying to put procedures straight in my mind.
By JaredKnight in forum Authoring (DVD)Replies: 1Last Post: 19th May 2007, 07:29
