I have about 100 different videos on my hard drive. All of them ranging from ASF to MOV to AVI
What I want to do is compress them all to a format that can be easily Decompressed later (To DVD, VCD or SVCD)
I was thinking of using DIVX or XVID and when I started doing this I started having a problem
One of the following would happen
1- I took a high quality movie and it became Crap
2- I took a low quality movie and it became bigger than the origional
What steps should I take to Copy a Movie from one Format to Another format at the same (or near same) Quality
Cade
You probably cannot compress the files any more without further loss of quality especially if you hope to ever use them again as dvd/svcd/vcd. The only exception to that would be very large files using a lossless codec like huffy or slightly compressed picvideo. I doubt that the files you are talking about are compressed with those codecs.
There's not much to do but then I can't do much anyway. -
I want to get all my files into the same format though. This is why I was trying to convert them all
Cade
How do I make my .mkv files smaller?
By nzdreamer55 in forum Newbie / General discussionsReplies: 6Last Post: 14th Sep 2011, 06:12 -
How to make dv captured files smaller and easier to stream?
By videomav in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2011, 12:22 -
How to make video files much smaller?
By crossword in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2009, 08:30 -
Re-encode files to make them smaller.
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2008, 19:27 -
How to make vob files smaller
By aruwin in forum Video ConversionReplies: 2Last Post: 26th Jul 2008, 15:25
