  1. ok this may not be relevent here. i am trying to burn a bin file on a cd. There is no cue file . Can anyone tell me what to do ? thanks.
  2. Search the forums for the term BIN2ISO for some insight on how to do this
    You should find about six messages that relate to your question.
  3. actually it shouldnt be too difficult....what kind of file is it? (SVCD, DATA) If you have Nero you can burnb without the cue...
  4. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    You can probably extract the data from the bin file using Isobuster and then burn the extracted files (whatever they are).
    There's not much to do but then I can't do much anyway.
  5. If it is a simple CD-ROM, then just burn it with Nero.
    If it is a S/VCD, I suggest that you regenerate the CUE/BIN image with the appropriate tool in VCDImager Tools GUI.
    Regards.
    Michael Tam
    w: Morsels of Evidence
