i want to convert an avi to svcd and i want the svcd to be exactly 700mb. how can i do that? i'm using tmpgenc, will i be able to do it with that?
If +/- 1-2mb is ok, then yes. Using the wizard towards the last step it will let you select your Bitrate, Filesize, and Target media. Type 700 in the filesize box.
FYI You can make it 800MB and it will fit on a 700MB CD-R, VCD/SVCD/CVDs use MODE 2 to burn, which makes a 700MB CD-R hold a 800MB VCD/SVCD/CVD. Basicly you can get a better image, with no drawback. If you want, make it 700MB and look at the CD-R afterwards, it wont be burned all the way to the outter edge.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
You can adjust the bitrate, but it wont show you the resulting file size, so I guess not w/o the wizard, or you could download a bitrate calculater from the Tools section, basicly you feed it the bitrates you are using it will tell you the file size.
Ejoc's CVD Page:
DVD:
Capture:
Some bit rate calcs also allows you to enter the movie length and the file size you want, giving you the bit rate to use to reach this size.
/Mats -
FILE SIZE = Bitrate * Time
TAMAÑO del ARCHIVO = Bitrate * Tiempo
VOLUME de FICHIER = Bitrate * Temps
AKTE GRÖSSE = Bitrate * Zeit
FORMATO di LIMA = Bitrate * Tempo
No matter how you say it ....FILE SIZE = Bitrate * Time
https://www.videohelp.com/calc.htm
thanks to ....
http://babelfish.altavista.com/
How to get output file size before converting a file using ffmpeg?
By hayden in forum ProgrammingReplies: 1Last Post: 26th Feb 2012, 07:04 -
Converting videos -> smaller file size
By karib in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 14:31 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Target file size not being met when converting to Xvid
By G)-(OST in forum DVD RippingReplies: 13Last Post: 30th Apr 2009, 09:07 -
Converting MPEG into a smaller file size?
By ione in forum Video ConversionReplies: 3Last Post: 9th Sep 2008, 22:36
