Okay, I'll burn a movie on Vcd, and when I play it on a Tv, it shows in fullscreen, so it stretches the the video down, so the video is all stretched. Does anyone know how to fix this? Maybe make it widescreen?
Results 1 to 11 of 11
"Be excellent to each other." - Ted Theodore Logan
btkuehn,
if you're using the Wizard/Templates then go to 'Arrange Setting' under 'Clip Frame' - this has the settings you're looking for i.e. 'fullscreen' / 'fullscreen keep aspect ratio' etc..
cheers,
mcdruid -
What pixels would I use to get a good shape (not stretched)?
"Be excellent to each other." - Ted Theodore Logan -
If you are creating VCD then the resolution is fixed and cannot be changed. When you load the VCD template in TMPGEnc the resolution and bitrate will already be set for you.Originally Posted by btkuehn
Okay, here's where I"m at now: I got Tmpgenc, I have this full movie on my hard drive, and I used Virtualdub to cut it into 5 parts, and I tried using Tmpgenc to change the size. I made the thing under Clip, arrange settings(like McDruid said) 640x272, and the aspect ratio 16:9 (or 9:16). And encoded it. Is what I did right? I want to learn how to make the shape of the video not stretched, like widescreen, so I can burn my other movies.
Thanks alot guys,
Bryan"Be excellent to each other." - Ted Theodore Logan -
Load the VCD template and use "full screen, keep aspect ratio" under the arrange setting. Encode the movie and burn it with VCDEasy. That should be all you need to do. Your source aspect ratio should probably be 1:1 VGA if it's an AVI file you're converting.
The VCD resolution will be 352x240 (NTSC- the USA) or 352x288 (PAL-just about everywhere else). This is normal and standard. If you change the output resolution it will not be VCD any more.Even a broken clock is right twice a day. -
btkuehn:
Please sit back and relax on Sunday, and read the Guides, its on the left in green under HOW TO, and readup on making VCDs. Every piece of information you are looking for is in there, and if you still cant find it, use the search feature on the top of the screen, thats what most of us did.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
webcam changes the shape of my head - How to fix?
By Electric Rider in forum Newbie / General discussionsReplies: 14Last Post: 3rd Nov 2011, 02:49 -
Are Premiere titles/shape vectorial
By elmuz in forum EditingReplies: 25Last Post: 21st Oct 2011, 00:50 -
How can I make MARQUEE to a video, Shape of overlay
By kailmursili in forum Newbie / General discussionsReplies: 2Last Post: 1st Jul 2009, 14:46 -
slide show - heart shape & floating hearts
By kj1983 in forum Newbie / General discussionsReplies: 2Last Post: 4th Oct 2008, 15:16 -
Changing the shape/size of an mpeg
By cawright1 in forum Newbie / General discussionsReplies: 13Last Post: 9th Oct 2007, 14:28
