I keep getting this error:
I am running it on the only partition I have. The password i am entering is also correct. I mounted the image and copied the files into a folder and ran the installer from there just to make sure that wasnt the problem. I also tried rebooting. No luck.[/code]Code:Run again the installer and make sure it is running on your primary hard disk and you're entering the correct OSX login password
Results 1 to 23 of 23
AnonymousGuest
AnonymousGuest
i got the same problem...
Unfortunately, I can only fix this problem if I can also replicate it on my computer. To do so, I would need as much detail as possible on your disk name, path names, osx version, login account type (is it an administrator account?). Please email such information at major4@mac.com and I'll do my best to fix.
Unfortunately, the installer installs more items than just the 3 located binaries, so it would be very difficult to give instructions to install with Terminal.
I think it's important to find out why the installers has issues for some users. The vast majority of users doesn't experience any problems. I would guess that a spinning ball or "Installation was not successful" error is due to installer not being able to register with admin privileges.
Normally these conditions should be met:
- logging OSX with an admin account
- running from a read/write partition
- no special characters in the path and drive name
- typing the right password
I noticed that some versions of OSX may in rare situations use a wrong keyboard map in password dialogs. Eg. if you type your password with a german keyboard mapping, the blind password field can sometimes switch to an english keyboard mapping. So it could be worth trying changing the account password to something very easy and matching all keyboards, like "iii". This is only a guess though.
AnonymousGuest
I tried the simple password to bypass the keyboard layout problem.
But no succes here.
I tried almost everthing else, even activation the root user.
Please help.
AnonymousGuest
Sup major, i figured out why my installer wasn't working, it was due to the fact i didn't have an administrator password, when i fixed my account up with a password, and had a go at reinstalling ffmpegx it suprisingly worked...could be the problem for others, peace
(i tried it twice after adding password, the first time it didn't work but second success.)
AnonymousGuest
Ok I got it working
- Renamed the copied diskimage to just "ffmpegX"
- copied the 3 components to the same folder as the installer
now it works...
AnonymousGuest
Could you be clearer, which files did u rename ?
AnonymousGuest
looks like the author doesn't care. who would ever consider buying a product the author won't/ does not know how to support it?
AnonymousGuestI agree. I considered buying a copy, but then they release this garbage and i am taking my money elsewhere now. How hard is it to make a working installer?Originally Posted by Guest
AnonymousGuest
The installer does not work for me either. Why does the author not care?
AnonymousGuest
I'm gonna make my own software called ffpmeg and it's going to be better because it has fewer letters.
I'm aware the installer having some issues in rare cases. Please read my two previous answers in this post.
The function which doesn't work in some situations is a very simple one, that is, registering with admin privilegs so as to copy the binaries in /usr/bin. This function is handled directly by OSX.
You should make sure the following:
- the installer must run from your desktop, not from the mounted dmg image
- your disk name and user name should not contain special characters
- your login account must be an admin account
In addition, it has been verified that sometimes OSX forces an english keyboard mapping in a password field. So if you have a non-english keyboard and type "a", it could get entered as "q" or something depending on the mapping. Try to type the password with an english mapping.
I understand that when something doesn't work properly it can be cause of stress. This problem never occurred on my machine, so your reports should be as precise as possible, and I'll fix every bug as soon as it is spotted and as long as it can be reproduced.
AnonymousGuest
Throw away the ffmpegX installer.plist from your home library, log out and back in and run the installer again. Fixed the problem for me.
ffmpegX 0.0.8c has new installer procedures. The main installer package can run directly from the dmg mounted image and will install everything but the 3 binaries you should download (mpeg2enc, mencoder and mplayer). For installing these, there is a new Engines installer application which will work fine for the majority of users.
If you still have issues and get the "Installation not successful" message, you can use Terminal as an alternate mean to copy mpeg2enc, mencoder and mplayer into the /usr/bin directory.
The command lines to use in Terminal are (assuming you have downloaded mpeg2enc, mencoder and mplayer on the desktop, and your username is "username"):
You should then set permissions to executable with these commands:Code:sudo cp /Users/username/Desktop/mpeg2enc /usr/bin/mpeg2enc sudo cp /Users/username/Desktop/mencoder /usr/bin/mencoder sudo cp /Users/username/Desktop/mplayer /usr/bin/mplayer
Code:sudo chmod 755 /usr/bin/mpeg2enc sudo chmod 755 /usr/bin/mencoder sudo chmod 755 /usr/bin/mplayer
AnonymousGuest
hey i finally got the engines installer to well ... install, but now when I try to install the "ffmpegX_installer.mpkg" I get passed the password screen, which I changed to install the engines, I click continue and then when it gets to the screen where you choose which partition, the only partitio has a red exclimation mark and says "You cannot install this software on this disk. (null)" what the hell is wrong now, and i have tried to install other programs and they have no problem
AnonymousGuest
same as guest as above: i installed every .pkg except "ffmpegX_components.pkg" which still has the red ! in a stop sign on my HD. i assume the .mpkg is a multiple package installer and at the "ffmpegX_components.pkg" is where the problem is... any suggestions
AnonymousGuest
yep, same problem - even copied all the installer files across to my desktop and I still get the NULL error.
AnonymousGuest
figured it out - when you get the CANNOT INSTALL error, just hit BACK then CONTINUE.
running the installer from the img file at the base directory of my primary drive, it works for me.
AnonymousGuest
thank you but why so much difficulty
AnonymousGuest
The hit back and then continu worked for me too !
What is windows installer for?
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2010, 13:51 -
windows installer?
By marcusden69 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 15th Feb 2009, 07:36 -
Windows Installer problem
By visjds1 in forum ComputerReplies: 3Last Post: 2nd Oct 2008, 13:03 -
avidemux installer problem
By jwfc in forum Newbie / General discussionsReplies: 6Last Post: 5th Jul 2007, 08:48 -
How to stop an installer from running?
By Duchess in forum ComputerReplies: 3Last Post: 3rd Jul 2007, 10:21
