Hi,
I'm trying to capture some TV shows with an ATI AIW 7500 card, but the SVCD preset in MMC sucks. Does anyone know of a guide somewhere that would help me get better quality? The only guides I've seen talk about VCD 2.0 encoding. Also, should I be capturing straight to SVCD compliant video, or another form and then converting it to SVCD compliant video with TMPGEnc or another program? Finally, what's the best program to edit out commercials? Thanks,
Matt
Results 1 to 10 of 10
www.lordsmurf.com
Only my guides cover DVD MPEG-2. However, you can easily change the resolution to 480x480, bit-rate to 2520 VBR, and audio to 44.1hz. The rest of it is identical.Want my help? Ask here! (not via PM!)
Make a new preset as the ATI MPEG CAPTURE guides show, then select VBR 2520, 480x480 and 44.1hz audio instead of what is shown.Originally Posted by ArcAnge1_1Want my help? Ask here! (not via PM!)
The VBR page has a slider that goes in MB/s...Am I going to 2.52 MB/s or what? Thanks.
Yep as close to 2.52 MB/s as you can. (it is very hard to get the slider spot on.)Originally Posted by ArcAnge1_1
Thanks for all your help. One more quick question: what is a good program to use to cut the commercials out and merge the remaining video? Thanks.
The best is womble mpeg vcr. (expensive at $120 though.)
You can use the cut and merge tool in TMPGEnc like a lot of other people do, but it is usually a bit inaccurate. -
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 15:45 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 12:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 14:01 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24
