When I first started using DVD shrink it worked fine. It would finish a 2hour long movie in no more than 30-40mins, sometimes less. But now it's taking 1 1/2-2hours to finish a 1 hr 30min movie. Is there some reason it's going so slow. Does it store files on my hardrive that I need to erase to make it quicker or something, or any other reason. Some1 please help.
Its a new feature in V3.5
It might have something to do with how much you are compressing your movie. if you are doing movie only and it all fits on a DVDr then theres no compression and it would be quick.
if you are doing compression dvd shrink has to read through the movie file and get rid of some stuff so it will fit on a DVDr, and this may take longer.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 21:31
