Was just wondering if anyone could answer this.
If I take a movie that I've originally encoded at a CBR using DivX to fit two 740MB CDs, and re-encode it using CCE at 4 VBR to fit on two 800MB CDs, will that increase the final quality of the new movie? Or does it retain the maximum bitrate used when it was compressed with DivX? A theoretical question, but I'd be interested to know if anyone has the answer....
TIA
JDC
you can't really gain quality that's not there. the best you can do is similar quality to the source.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Originally Posted by joedotcom
BTW, I agree with Conquest10 regarding quality. You can't create something from nothing; Or the often used "Crap in = crap out.""Art is making something out of nothing and selling it." - Frank Zappa -
The best you can hope to do is get the exact same quality, but in practice the re-coded video will almost always look worse unless you filter a really bad video file.
You can't add quality back to a video, once it's gone through compression, you're getting it back. Many people will tell you that you can add a little quality back, but it typically involves bluring your video to hide compression. Just remember garbage in, garbage out. There is no way to add quality back to a video once it's gone.
In order to achieve a higher bitrate you'd have to re-encode from the original source. Otherwise, it's just wasted space making it bigger.
The only reason I would concider encoding a divx to svcd is so that I could watch it on my DVD player. I have encoded divx to dvd and they look pretty good, no where near as good as a true dvd though.
"Terminated!" :firing: -
Ok - thanks to everyone, I guessed as much. I just thought that maybe since I'm giving the movie more space and doing a VBR, higher bitrates would result, but I get your point. Thanks again.
JDC
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
DIVX Movie Converting?
By RecoveryTTA in forum Newbie / General discussionsReplies: 0Last Post: 22nd Sep 2010, 20:22 -
Quality loss in converting from DIVX to XVID?
By fwtong in forum DVD RippingReplies: 7Last Post: 25th Jan 2008, 17:37 -
What program gives the best quality results, when converting AVI/DIVX/XVID
By Rockstar452 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 01:19 -
converting .avi (divx) to dvd and keeping original quality...
By RushMaster in forum Authoring (DVD)Replies: 15Last Post: 22nd May 2007, 14:47
