I want to order this DVD from a japanese site, but it says it is region 2, which means it won't work on my dvd player. But will it work if I watch the DVD on my computer?
If you look at the properties for your DVD drive in the control panel/system area, it will allow you to change the region up to 4 or 5 times. That could be a temp fix for you to watch it.
Now there are numerous patches floating around the net to permanently make your drive region free. A simple google search of 'make dvd drive region free' worked great for me.
As for your DVD player, depending on the make/model, they can be hacked as well. I downloaded a region free bios for my APEX and uploaded it to the player. It also let me change the graphic and other things. Try a search for 'MAKE MODEL hack', filling in your make and model.
Hope that helps. -
You can also look up your player in the "DVD Hacks" section right over there <<<<<<<<<.
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
Dvd hacks needed
By poisonivy4 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Jun 2010, 10:38 -
dvd hacks - lg dvx492h
By lynsey in forum DVD & Blu-ray PlayersReplies: 0Last Post: 2nd Jan 2010, 17:50 -
lcd tv with dvd built in----hacks
By CODEWERKX in forum Newbie / General discussionsReplies: 0Last Post: 8th Dec 2009, 09:15 -
Question about hacks
By Asmodee in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Jan 2008, 12:36 -
DVD hacks section problem?
By steveryan in forum FeedbackReplies: 3Last Post: 26th Jun 2007, 11:55
