I am new to this program (version 1.5.11.37).I am making a DVD+r with it that I plan to compress using another program before i actually burn it.I have pulled from numerous source materials for the video.There are 36 tracks with one (short) chapter each in my project.
After authoring and before encoding in DVD Author,I get this message:
The combined bitrate of the clip exceeds the upper limit for a dvd standard.The current bitrate is video 9800 kbs,audio 192 kbs,combined 9992 kbs.The combined audio and video bitrate can't be more than 9.848 mbps (9848 kbs).
Can someone tell me the best way to go about tracking down my problem without having to experiment by removing items?Also,can this explain why 4 of the tracks had no audio after I decided to encode the project anyway?![]()
lower your max video bitrate to say 8800 ...
the rest of your question(s) i dont understand what you are asking .. or enough info is given .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks for the response.The only place I see in the program to alter max. bitrates is in the "track settings" (for each individual track) under the "source setup" tab.These boxes are grayed out.Anyway,Do you know if there is a way to set bit rate maximum for the entire project so as not to have to do each track individually?
My other question concerned a loss of audio on certain tracks after DVD Author encoded everything.If you can assist in guiding me as to what to do to get the bitrate settings down,I suppose I'll just wait and see if the audio loss happens again.Thanks -
It depends on where TmpGenc DVDAuthor is getting the bitrate info from as to what you need to do. If I understand correctly, the mpg file header includes a filed that indicates the Max bitrate of the video or system stream. This is not always correct but if this is the info used by Tmpgenc DVDauthor, then it may explain the problem you are seeing. You can check each of the video in bitrate viewer, and see the actual bitrate used. You can then use DVDpatcher to patch the headers of any files that report a too high a bitrate.
Hope this helps. -
Thanks Bugster! Forgive my ignorance of all things "kbs"
Am I correct in assuming that my error message referred only to whatever source material I was using that exceeded 9848kbs if you add together both the video and audio values of the offending individual clip(s)?And that if I make the necessary adjustments on only those clips individually to lower their values below 9848kbs that I will be O.K.?I wasn't sure if if had to make some kind of adjustment to all the clips in my project evenly to bring down their collective average value.
Originally Posted by Otterpup
Otterpup
I use CCE Basic for encoding and it always writes 9800 as the bit rate regardless of the actual bit rate. Likewise, I always get the same message in Tmpgenc DVD Author. I simply ignore the warning and continue--I've never had a problem with the resulting DVD.
wwaag
Invalid audio bitrate error on TMPGEnc Authoring Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 12th Jun 2010, 23:13 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 11:16 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 17:20
