First I use Smart Ripper, then I do the usual in DVD2AVI (ie, open find vob file, then save.... and away it goes. I have noticed on this certain film that it is not taking that long)
Also when I go into TMPGenc, it can finf the video file, but no audio, and when I select all files it saying the word delay on the audio file, so not sure what the probelm is.
Please Help!!
AC3 tracks have a delay on them. The file name has Delay blah-ms because that is how many miliseconds the file is delayed. So when you encode you can take out the delay.
Sounds to me like the audio is missing, in which case, try under the "audio" tab in DVD2AVI, and select a different track No.
Track No.1, is the norm most of the time, but for some reason,
I find some like to be different (just to annoy you) and put the audio
on a diff. track!
Hope this works and good luck!!you say Y,
I say Y not?
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
