Need some help fellas I keep getting constant blue screens on my current system. It had been restarting for "No Reason" ever since I installed XP. I then followed the instructions on here on how to prevent that. Well the system no longer restarts it just posts a Blue Screen. I don't understand why it is doing that. Two things that I have thought of would be heat issues or my PSU. My CPU only gets up to 124F which dosn't seem to hot to me but the idle temp is only 104F. I still don't think thats the issue but maybe. Now my PSU is 350W (rated I think its a cheap Taiwanesse PSU though) could it be possible that my PSU dosn't have enough power and if so can that cause my system to blue screen? Below are my system specs so you know whats in here
P4 3.0c
Intel D865PERL mobo
2x512 Kingston DDR400 Ram
Radeon 9800 AIW Pro w/ that little power connector on it
2x120GB SATA Drives in RAID 0
2 ATA Hard drives (1x100GB, 1x60GB)
Pioneer AO5 DVD Burner
Also here is what Intel Active Monitor is saying about my power
Volts(12v) 12.125
Volts(5v) 5.104
Volts(3.3v)
CPU Core(1.55v) 1.518
CPU I/O(1.5v) 1.458)
I noticed the system seems more likely to crash when I open Nero although I don't think its the software, because it seems to crash when the DVD Burner spins up the CD, I noticed the power drops a little bit on Intel Activie Monitor when I read a DVD/CD.
Any suggestions would be fantastic!
I would assume you made no hardware changes before the XP install? Virus and PS problems are two possibilities. Did you do a clean install of XP or put it over the top of your old OS?. This can cause problems. I always partition and reformat before an XP install. Can you restore to an earlier date or is your install too new?. Another thing that doesn't hurt is to unplug your computer and reseat every connector on the MB and the chips and plugin boards. Also can you run in safe mode?. If you can run without the BSOD's, it may be a driver or software problem. I hate to say it, but I usually just back up my files and reformat the HD. May be a big hassle, but you can get real tired of the BSOD's (Blue Screen of Death for you Mac fans). Good luck.
Have you tried a complete re-install?
Sumpin's screwed up. DL the newest drivers for the other hardware, if you buy a component 3 months old, you can be sure the drivers are 9 months old, or more.
And a ton of stuff is not really compatible with XP, hell, a lot of companies admit they have no intention of re-writing drivers FOR XP. Throw that card away. We don't care.
You should not BSOD. Of course, you could "upgrade" to W2k.
George
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30 -
Again blue screen!!!
By alintatoc in forum ComputerReplies: 10Last Post: 10th Dec 2009, 15:16 -
Blue screen?
By alintatoc in forum ComputerReplies: 19Last Post: 1st Nov 2009, 07:53 -
what's a blue screen?
By aruwin in forum ComputerReplies: 8Last Post: 23rd Sep 2009, 09:56 -
Blue Screen Of Death
By Squid_uk in forum ComputerReplies: 15Last Post: 31st Mar 2008, 15:35
