Hi. Is it possible to take a DIVX movie with AC3 encoding, and convert it to a DVD keeping the AC3 surround sound? I have both platforms (Mac and PC). Thank you.
Use the search and you will find a lots of tips, search for ac3 divx
Like this:
https://www.videohelp.com/forum/viewtopic.php?p=637645#637645 -
I had a Xvid file with AC3 audio. I have managed to seperate it to a M2V video and a AC3 audio (corrected with AC3fix) ready to multiplex it and author it before burning to DVD. The guides and posts have got me this far, but one guide said I could multiplex it in TMPGEnc. Can anyone tell me which type of mpeg do I need to set it to?
When done, I will be authoring with TMPGEnc DVD Author and burning with Nero. As a newbie to DVD (12 months on VCD`s) I need a little help.
Great. I hadn`t noticed that. I`ve only used mp2 before and had no probs.
Everything went fine until I came to the make vobs part. It came back with " a required dll is missing, PSAPI.DLL."
I`ve searched for it and it appears to be connected with NT.
This is a problem as I`m running WinME.
I know this is to do with IDE comunication and drives.
Is there a fix or am I destined to only do PCM audio?
Your help so far has been most appreciated.
Dare I ask for still more?
Thanks again. -
I too have winME and can't use the 'burning' function (same .dll missing). I think the program is only for full use on XP or win2k (NT).
However your VOB,s should be OK as I only get the message if I press the 'open DVD writing tool' button. The VOB's and folder structure should already have been complted. It seems that you need some other burning sofware -
I must be getting tired. That`s what I did. I`ll go back to my original plan and vob it then burn with Nero.
2A.M here so I`m on my way to bed. I will post my success (hope, hope) tomorrow as possible help to others with similar challenges.
My deepest gratitude for all your help.
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
DVD to MKV while keeping DTS and AC3??
By SilverBlade in forum DVD RippingReplies: 1Last Post: 13th Mar 2008, 15:52 -
DVD to x264, keeping AC3 audio, chapters, subtitles?
By Valnar in forum Video ConversionReplies: 2Last Post: 29th Dec 2007, 23:45
