OK..... I know you've probably heard this so much you want to barff just looking at the subject, but I'm completly lost.
Every Xvid file I try to playback on my machine has an audio sync problem, I don't get it. Every other format plays with no problems at all, can anyone tell me what is causing this?
I can get by with DIVX, but everyone seems to be using XVID and unless I can sort this out my choices are going to be extremely limited.
Again... sorry to repeat a subject I know you must have heard before
Your computer is probably too slow. XVID requires ALOT of the machine, mainly the CPU. My PIII-1Ghz LapTop won't play all the XviD's, but my P4-2,4 GHz will.
You can always convert the XviD to SVCD/VCD or DVD... that's what I do -
Turn off Post-Prossesing in XviD, that is what absorbs all the power. XviD and DivX are about tied in terms of quality. The newest DivX (5.1) has great quality, reasonably better, but is sooooo much slower than XviD. Then XviD is gonna be better then DivX for a while, then DivX better than XviD. It goes back and forth. Just know that DivX is going to be more hardware compatible, because they are already so well established.
i got a p3 667 and have no problems with xvid.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
What? no DV option
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
Subs Help - Driving Me Bananas ...
By DaveWillow in forum DVD RippingReplies: 2Last Post: 14th May 2010, 10:40 -
Conversion size is driving me crazy!
By artdog in forum DVD RippingReplies: 8Last Post: 27th Apr 2009, 12:33 -
Printer driving me nuts
By bryankendall in forum Newbie / General discussionsReplies: 4Last Post: 27th Dec 2008, 09:47 -
This file is Driving me Crazy! suggestions plz
By k_oss_22 in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 00:40 -
Help! I'm going crazy trying VirtualDub to encode to Xvid
By hdnine in forum Newbie / General discussionsReplies: 9Last Post: 17th Dec 2007, 09:07
