In premiere 6. Is it better saving my Movie (from my camcorder) as "Microsoft DV AVI or Microsoft AVI" or something else. Should i save the Pixel Aspect ratio as "Square Pixel o0r D1/DV Pal 1.067". All this before i put it through the tempge program. Thax in advance
You may be better off frame serving the Premiere timeline with Avisynth directly into TEMPGEnc. It will save steps and keep quality high.
I've never used this method because I have Premiere 6.5 and use it's Main Concept encoder. I've read that many people frame serve out of Premiere 6.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I don't think you can frameserve from Premiere with Avisynth.
I know for sure this works:
DebugMode PluginPac FrameServer -
premiere 6 is pretty crappy when it comes ot DV anyway .. you should upgrade to 6.5 or pro .. instead ..
Saving Avidemux settings to a preset, how to?
By Diana (Cda) in forum Video ConversionReplies: 12Last Post: 30th Aug 2012, 23:00 -
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 18:13 -
Settings for Premiere smart render/how to tell if it's working...
By rcavanah in forum EditingReplies: 8Last Post: 14th Sep 2011, 18:20 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Canon PowerShot video settings in Adobe Premiere
By w00ties in forum EditingReplies: 2Last Post: 11th Jan 2009, 23:16
