Ok,
I'm converting a Widescreen SVCD to DVD as follows:
Extract MPEG stream using ISOBUSTER
Import into TMPGEnc+ and select DVD template from Wizard
Select 'Full Screen Keep Aspect Ratio'
Set the bit rates
Convert
Burn to DVD Video
The result is fantastic quality, etc. except that the aspect ratio on my widescreen is too wide. Almost like a stretched 4:3 picture. I have to zoom the picture vertically to get proper aspect.
What am I doing wrong? Should I be selecting an output aspect ratio of 16:9 from TMPGEnc+?
Any help would be gratefully received,
TIA,
Jukka
Set the Source aspect ratio to 4:3 display and Video arrange method to Full screen(keep aspect ratio). SVCD is always 4:3(if it is widescreen it is 4:3 but with black borders).
Then check the file->preview and it should look okey.
DVD with 16:9 aspect ratio truncated on Vizio widescreen TV
By gschmidt in forum Authoring (DVD)Replies: 14Last Post: 29th Oct 2011, 17:48 -
Aspect ratio for SD Widescreen on YouTube
By matthewjohn23 in forum Video ConversionReplies: 9Last Post: 1st Nov 2010, 18:14 -
Converting from Mini DV - Problem with Aspect Ratio PAL Widescreen
By Videonisse in forum Capturing and VCRReplies: 9Last Post: 30th Jun 2009, 17:01 -
How would I combine these avis into widescreen or TV aspect ratio?
By Han Solo1 in forum Newbie / General discussionsReplies: 9Last Post: 6th Mar 2009, 16:48 -
Watching AVIs in normal aspect ratio on a widescreen TV
By fiiido in forum Newbie / General discussionsReplies: 6Last Post: 9th Aug 2007, 07:05
Thanks Baldrick
