Nothing I encode using mencoder ends up with an audio track!
This is true with any mode (MPG4, XviD, or DivX3) and with any audio setting (MP3, MP2, AC3, passthrough). The sources are DV/DVCPRO-NTSC which encode fine using ffmpeg.
Is this a known problem?
khromagenGuest
khromagenGuest
Changing the extension to .dv didn't work.
But re-exporting the source from QuickTime as a DV-DVPRO-NTSC .mov with uncompressed audio does. I can only assume the original sources (created in Premiere and exported without compression) had something in the audio track mencoder didn't like but ffmpeg can handle. Can't imagine what it is.
Mencoder's output for this project (dance performances) is excellent - considerably better than ffmpeg's or QT's MPEG4.
As an aside, ffmpegX Progress's progress bar doesn't update when encoding with mencoder.
[/u]
[mencoder] No audio in last few seconds after encoding?
By MacDada in forum Video ConversionReplies: 0Last Post: 27th May 2011, 11:03 -
Mencoder and Audio Quality
By kage123 in forum AudioReplies: 2Last Post: 26th Mar 2010, 16:14 -
PCM audio in MENCODER
By zepperdude in forum AudioReplies: 1Last Post: 16th Oct 2008, 21:56 -
Can't encode file with audio with Mencoder
By ApplePro in forum Video ConversionReplies: 8Last Post: 12th Feb 2008, 06:38 -
Any audio to mp3 with mencoder
By crirus in forum ProgrammingReplies: 5Last Post: 1st Jan 2008, 23:31
