would it make any difference whatsoever if i capture at 720x240 instead of 352x240?? either way i use TMPGE to encode at 352x240. i'm just wondering if capturing at 720x240 would give a better picture before the encoding rather than 352x240. or would it be the same since the output after encoding is 352x240??? i'm just looking for another tip on the subject of better input better output....
Results 1 to 1 of 1
PAL or NTSC camera : does it matter ?
By kirby7777 in forum Authoring (Blu-ray)Replies: 9Last Post: 14th Aug 2011, 14:51 -
Does size really matter?
By ingeborgdot in forum ComputerReplies: 21Last Post: 25th Jun 2011, 10:11 -
So is any DV codec better than MainConcept at decoding? Does it matter?
By Asterra in forum Video ConversionReplies: 11Last Post: 20th May 2011, 22:59 -
Can't get DivX to work with AutoGK no matter what I do.
By teapot in forum Video ConversionReplies: 4Last Post: 17th Jun 2010, 22:38 -
Filter order matter in editing?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 6th Jun 2007, 16:54
