Hello. I have a problem using the "DoItFast4U + CCe + Scenarist" method.
I had made some DVDs backups perfect but in some DVD's i can't.
The reason is the dvd structure. Some chapters have "00:00:00.12" (only 12 frames) and i don't now how to process them.
The guide only says: "But if you look hard enough you'll see that this VOB ID is the layer break and only 15 frames seconds long. In this case you can also process by PGC. All you have to do is add a chapter point at the end of each PGC, exactly 15 frames from the end of the track.".
I try to add a chapter point at 12 frames from the end, but the scenarist says: "Scene duration shall be more than 0.4 second.", and i have to add the chapter a few before.
When I use the IfoUpdate, I have a problem with the times. It says:
- Procesing VTS_PGC_0
- WARNING: Source to Destination mismatch
Original time = 00:00:00
Newly Authored time = 00:00:01
Then, when i burn the disc, i cant see the menu, only the videos before the menu.
Other problem is that when i open the IfoEdit and open the VIDEO_TS.IFO and go to "Get VTS sectors". It says: "Attention: A Menu-Vob file was found, but there are no MEnu-tables in this IFO file!. Though you will have a big problems on burning this directory, or playing back the DVD-R!. You better delete the following menu file and redo a 'Get VTS Sectors'!. C:\....\...\authored\VTS_01_0.VOB" and the same for the other VTS_xx_0.VOB.
I need that you explain me how to process the 12frames chapters. Thanks.
Next I write the structure of some dvd.
(If you don't understand something I wrote, i'm sorry, but i'm not english. )
In Gangs of New York (SpanishVersion), in the VTS6:
PGC_1 (program chain): [title(TTN): 1][00:00:17.00 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1)
[Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/1] : time: 00:00:17.00 / 25 fps [Pos: 00:00:17.00] [Frames: 425]
PGC_2 (program chain): [title(TTN): 1][00:00:00.12 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 2)
[Ch 02] [Pg 01] [Cell 01] [V/C Id: 2/1] : time: 00:00:00.12 / 25 fps [Pos: 00:00:00.12] [Frames: 12]
In Lord Of The Rings (Two towers) (SpanishVersion), in the first VTS:
PGC_1 (program chain): [title(TTN): 1][02:52:04.12 / 25 fps] (Programs: 54) (Cells: 55) (uses VOB-IDs: 1,2,3)
[Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/1] : time: 00:03:58.16 / 25 fps [Pos: 00:03:58.16] [Frames: 5966]
[Ch 54] [Pg 54] [Cell 55] [V/C Id: 3/1] Layer Br.: time: 00:00:00.12 / 25 fps [Pos: 02:52:04.12] [Frames: 258112]
PGC_2 (program chain): [title(TTN): 2][00:00:00.12 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 3)
[Ch 01] [Pg 01] [Cell 01] [V/C Id: 3/1] : time: 00:00:00.12 / 25 fps [Pos: 00:00:12.00] [Frames: 12]
And the second VTS (Two Towers) is:
PGC_1 (program chain): [title(TTN): 1][00:00:17.00 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 3)
[Ch 01] [Pg 01] [Cell 01] [V/C Id: 3/1] : time: 00:00:00.12 / 25 fps [Pos: 00:00:00.12] [Frames: 12]
[Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/1] : time: 00:00:16.14 / 25 fps [Pos: 00:00:16.14] [Frames: 414]
[Ch 02] [Pg 02] [Cell 02] [V/C Id: 2/1] Layer Br.: time: 00:00:20.20 / 25 fps [Pos: 00:00:37.09] [Frames: 934]
[Ch 03] [Pg 03] [Cell 03] [V/C Id: 3/1] Layer Br.: time: 00:00:00.12 / 25 fps [Pos: 00:00:37.21] [Frames: 946]
PGC_3 (program chain): [title(TTN): 3][00:00:00.12 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 3)
