Since i upgraded to 1.5 i have been having major problems. The rip bin files works fine but when it tried to Re-encode the audio i get the error message that the file is not a valid MPEG file.......
This happens on every movie i try it on... Any ideas folks.. I am on the latest release of everything
here is the error log
clipping detected : 0.683571dB
Encoding Time 418secs.
******** Multipexing elementry streams
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [mplex] File F:\newmulti\***S.SVCD_InR\CD1\inr_mma\inr_mma_01_D VD.mpv unrecogniseable!
INFO: [mplex] File F:\newmulti\|***.TS.SVCD_InR\CD1\inr_mma\inr_mma_0 1_DVD.mpa looks like an MPEG Audio stream.
**ERROR: [mplex] Unrecogniseable file(s)... exiting.
F:\newmulti\***TS.SVCD_InR\CD1\inr_mma\inr_mma_01_ DVD.mpg is not a valid mpeg file
||||||||||||||||||||||||| PROCESSING ABORTED |||||||||||||||||||||||||
Hey,
Is the audio bitrate of your file 44.1khz? If it isn't then it won't work.Greatings,
Yf
valid ts file
By qman7112 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2011, 15:35 -
x264 log file
By txporter in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 15:40 -
FAVC log file
By marioval in forum Authoring (DVD)Replies: 3Last Post: 31st Jan 2008, 06:17 -
Audio CD with an avi file added
By Sskafar in forum AudioReplies: 3Last Post: 17th Dec 2007, 21:19 -
Not a valid avi file and Unable to insert......
By tommyboy9495 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2007, 22:11
