  1. Is it possible to convert PAL to NTSC and have it synch correctly?
  2. The framerate change doesn't work quite well, unfortunately. I will try to improve this kind of conversion, even if many TVs and DVD Players today allow to play both PAL and NTSC.
  3. Thank you. It would be a nice feature to have. My DVD player will play and convert both to NTSC. However, I just notice that Toast 6 forces you to select one or the other. If there is a mix, it says that it work.
