Your help will be most appreciated if someone could tell me how I can burn a Video Clip onto a DVD.
Here is a jpg of the video clips properties.
I have installed:
Nero Burning 6 and InstantCD+DVD
Trying is the first step towards failure.
--Homer Simpson -
You need to ensure that your video clip is an MPG and is DVD compatable. Re-encode it with TMPGEnc using the wizard. You only get DVD (mpeg2) encoding for 30 days, but mpeg1 encoding is free (mpeg1 can also be burnt to DVD - lower quality, but smaller file sizes)
Once encoded, you must author your DVD in order to create your VOBs, IFOs, and BUPs. TMPGEnc DVD Author is perfect for this, and has a 30 day trial version.
Once you have on your HD a VIDEO_TS folder containing your authored files, you need to burn it to a DVD in DVD Video mode, I find that CopyToDVD does a very good job of this. -
Thank you Chillsdon!
--Homer Simpson -
also...
if you do not want to waste a DVD, use TMPGEnc to encode to VCD compliant mpeg1, then use VCDEasy to burn mpeg1's to a (S)VCD (normal CDR) which will also play in good DVD players.
Nero 5.5 also burns (S)VCDs
VCD is made up of mpeg1's, SVCD uses mpeg2's, but at a much lower bitrate than DVD. -
What would you recommend?
SVCD or VCD?
Sorry, I'm just a newbie
--Homer Simpson
Burning Video clip files to DVD
By boraborasands in forum Authoring (DVD)Replies: 1Last Post: 14th Dec 2010, 09:32 -
Just want the video clip using DVD-lab PRO 2
By WTRanger in forum Newbie / General discussionsReplies: 13Last Post: 29th Oct 2010, 06:18 -
video clip rip from dvd
By xxxjojoxxx in forum Newbie / General discussionsReplies: 5Last Post: 21st Feb 2009, 13:08 -
Capture Video Clip from DVD
By dtexas in forum Newbie / General discussionsReplies: 2Last Post: 21st Apr 2008, 08:52 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 09:26
