  1. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    what software should i try to do this.
  2. For simplicity, you can try TMPGEnc DVD Author, but bear in mind that you can only have 1 audio stream and no subtitle. Use TMPGEnc DVD Author to create a new DVD structure with the 2 movies that you want to combine on one DVDR. You can also creat simple menu with this tool. If the total file is too big you can always use other tools to shink it to fit onto 1 DVDR such as DVD Clone, DVD2One, DVDShrink... Remember that you'll lose 10-20% video quality or more if your 2 movies are too long.
    Do you mean captured movies or avi/divx movies to one dvdr or 2 dvd-video movies to one dvdr?
  4. Member Sifaga's Avatar
    Aug 2003
    Thankyou for that, i will give this another go
  5. Member Sifaga's Avatar
    Aug 2003
    Im trying to put 2 dvd-video movies to one dvdr
    I just tried TMPGenc DVD Author, now Im trying DVD-Lab and DVD2ONE next
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Okey, then I'm moving you to the dvd to dvdr forum.
