I got the worst problem after my drive got upgraded firmware ( to v1.51).
I could burn the dvd+r since then. it burned almost 80-90% and causing an error. I am using ( Nero6.0.0.15, Img Tool, Record Now Max, copytoDVD, clonedvd); it had an error every time I burned dvd movies and if burning data dvd+r is fine.
I bought the Ritek dvd+r at "allmediaoutlet.com", I am afraid that the problem is caused by the media. what you guys think? thanks.
any has the same my problem or any one has any idea. please help.
thanks alot.
hi guys,
I just found out that the problem is caused by the usb drivers.
b/c I thought that my system has usb1.1 or the dvd burner needs usb 2.0 , is it right. and how can I check to know what version of usb is on my system. thanks alot. I just don't know if I posted the wrong place again??
newbie.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
