Do I clean it the same way I would a DVD?
Hey there Bob W!
Novus Polish ought to do the trick, check out this link: http://www.laserdiscarchive.co.uk/laserdisc_archive/novus_cleaning/cleaning_laserdiscs.htm
Good luck!I only dream in black & white...
MSN: paschendale@gmail.com -
or even wash it under warm water with dish soap. just make sure it's dry before you use it
"Terminated!" :firing: -
I used to use an automobile product from Eagle1. They had a plastic cleaner and polish that worked great at covering the scratches. That was the only way I could get some ex-rental discs to play.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Capture laserdisc audio (s/pdif to PC)
By digitalfreaknyc in forum AudioReplies: 13Last Post: 5th Aug 2010, 09:49 -
Current recommendations for Laserdisc conversion
By tonyaldr in forum Video ConversionReplies: 3Last Post: 19th Jan 2009, 09:06 -
Laserdisc: Blade Runner
By vhelp in forum Off topicReplies: 11Last Post: 1st Aug 2008, 23:19 -
LaserDisc to DVD!
By hellhole in forum Video ConversionReplies: 4Last Post: 1st Oct 2007, 02:07 -
LaserDisc to DVD with TmpgEnc Xpress 4.0
By sapulidi in forum RestorationReplies: 5Last Post: 16th May 2007, 12:42
