Hello, I just bought a Lite-On 166s and put it in a USB 2.0 enclosure. When I try to rip a dvd in ISO mode "read", I get a message "Drive is busy". Dvd decrypter works well with my pioneer 106d but the rip speed is slow, so I bought the Lite-On Dvd Rom.
Decrypter recognizes the Lite-On drive because I'm able to select it for the source but when I begin to read, I get the "Drive is busy" message and then my Lite-on external drive is locked and decrypter freezes and I have to restart my pc.
Any suggestions?
I don't really know- but if it was me (and if you don't get a reply from someone who knows more than me- which probably just about everyone here) then I'd try plugging it in the IDE cable instead of USB and see if it works then.
I'm able to use the lite-on and the pioneer 106d external usb 2.0 with another dvd backup software and the lite-on is able to read and rip the dvd....I don't know what else to check....I'm using Windows XP and I'm able to use the lite-on with other applications.
I also uninstalled my other drives and only had the lite-on but dvd decrypter still says "Drive is busy" when I try to read in ISO mode.
When I installed the lite-on external usb 2.0, Windows XP recognized it and I didn't have to install any drivers.
Are there some drivers that I may need to install? I really love using dvd decrypter and I'm frustrated that I can't get it to work with the new lite-on.
Please, anyone....help...thanks -
Try these tricks:
1.play DVD for one minute in PowerDVD or WinDVD.
2.make sure DMA is enabled.
3.d/l ForceASPI Drivers. -
It's ABSOLUTELY an interaction of some sort between the USB enclosure (USB drivers) and the ASPI layer.
I always recommend AGAINST USB for this very reason. I use firewire. But then again, Firewire sometimes has this problem as well. It's sort of a hit-or-miss thing. ASPI just plain sucks, and always has.
- Gurm -
It's a problem with DVD Decrypter and the 166.
Here is what Lightening UK ad to say on a forum near you :
Liteon 166 (and some 165) drives are weird and dont work in the same way as all the others I have tested.
The normal i/o key exchange fails for reasons I wont go in to and hence the old brute force method kicked in.
I've implemented a work around for this in the next release.
Maybe v.3.1.7 will be out soon
... until then ... you could try AnyDVD
Lite-On Burner Will Not Read DVD+R Media
By kca741979 in forum MediaReplies: 11Last Post: 28th Feb 2010, 02:47 -
Why does my Lite-On DVD burners fail on 8x DL discs?
By Onceler2 in forum MediaReplies: 26Last Post: 5th Jul 2009, 02:11 -
Lite-On A110 DVD recorder, problem with RW discs
By Jack_Dante in forum DVD & Blu-ray WritersReplies: 1Last Post: 7th Apr 2009, 10:50 -
DVD Decrypter wont work with my external drives?
By dazza555 in forum DVD RippingReplies: 4Last Post: 23rd Jun 2007, 20:04 -
Anyone have Lite DVD Recorder On DD-A100GX ? ? ? ? ?
By HolyGeez in forum DVD & Blu-ray RecordersReplies: 8Last Post: 30th May 2007, 09:58
