OK,
I'm tired of everything having to be converted to a seperate audio and video track before burning. Since ATI'S mmc has everything captured directly to a single mpeg file, isn't there a program that would accept just that, burn it, and still work perfectly in normal dvd players?
Which MMC version are you using? I use ver 8.5 and Ulead DVD movie factory 2 accepts all MMC's dvd profile without any problem.
I use TMPGENC DVD Author. It accepts MMC's DVD settings. More than that it accepts VCD setting even for authoring DVD's which allows me to put seven hours of TV on a DVD at good quality. (I use the vcd setting with a combo1 filter set at 60 and a sharp filter set at 15. It takes the vcd video which usually looks a bit washed out and really improves it)
Videosoap in ATI MMC. Couple of questions
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 12:49 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 17:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 03:14 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 20:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 22nd May 2007, 23:44
