I'm using TMPGEnc Plus 2.5. I'm trying to encode using stream type SYSTEM instead of ES (Elementary Streams) but when I get to step 5/5, the option to "Output video and audio as indiviual elementary streams" is gray'd out. How do I get the option back to uncheck the box? The "Help" file says something about having to use a DVD template...what is that?
Thanks,
ChachiFace
Trying to encode WHAT ?
If you don't have both audio and video in the input I suspect that
the program will have a hard time making both separately.
A system stream can have no audio -
The audio and video are in the input (.avi)!
I think I just found out by trying different settings that I cannot produce a System stream file (.mpg (audio + video) using PCM audio (which I am using). It has to be ES.
I encoded the .avi file as ES (elementary streams: .m2v & .wav). Then using the MPEG tools, muxed them together. That seemed to work.
ChachiFace -
A system stream is a multiplexed video with audio stream. This is why you cannot select to output individual ES (Elementary Streams) at the same time.
Now, your explanation is rather confusing. You say that your audio is in the AVI. Then you say you use PCM audio.The more I learn, the more I come to realize how little it is I know. -
It depends on the audio type you pick on the first tab of the wizard.
If you pick PCM, you have to go ES.
Pick MP2 and you can create an MPG with both streams.
Greg -
EXACTLY.Originally Posted by Holden
Some guys just dont use the program enough to comment.
Got it now...PCM is ES only. MP2 is SYSTEM. Also figured out that you can't mux PCM audio with MPEGII video. Thanks for the responses.
MP4 Stream Multiplexing Type Compatibility
By datbates in forum Video ConversionReplies: 0Last Post: 27th Jun 2011, 02:49 -
Looking for simple system to stream video to TV
By ovide_video in forum Media Center PC / MediaCentersReplies: 7Last Post: 21st Dec 2010, 15:08 -
Stream type mismatch - 19023 with DVDit Pro 6 Redux
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 21st Apr 2010, 18:24 -
how to stream video in a security system?
By marada in forum Video Streaming DownloadingReplies: 0Last Post: 29th Dec 2009, 17:28 -
Type: System.UnauthorizedAccessException
By pod01902 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th May 2007, 00:21
