Results 1 to 11 of 11
  1. Hello
    I have a problem with TMPGEnc , when I try to convert to VCD I get this error message:
    "write error accured at address 00401C9F of module TMPGEnc.exe with 0284C604"
    does anyone know what this means?
  2. No
    ...but try reinstalling the prog/ restarting your computer and see what that will do.
  3. ok , i reinstalled it .But It does the same thing, or it crashes.
  4. Try checking for bad frames with Virtualdub (MP3 Freeze Version)
    "Today is only yesterdays tomorrow"
  5. hm just keeps crashin
    anyone know some other good avi - vcd converter programs?
  6. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    Or the file is huge and you don't frameserve to TMPGenc or you don't have enough temporary Hard disc space, or you output to a HD with not enough space.
    So: Frameserve to TMPGenc, set TMPGenc's temp folder to be on a HD with more than 10GB of space and check if your TMPGenc output file is on a HD with enough space.
  7. i have plenty of space
  8. The Old One SatStorm's Avatar
    Then set the temp folder of TMPGenc to use this space.
    Also, frameserve your source to TMPGenc.
  9. Also, dont use a very long filename, esp one with lods of dots (full stops) in it.
    e.g If your filename is somethinsg like:
    this.is.my.best.ever.home.move.that.I.have.made.(divx 5.0).avi
    change it to: movie.avi
    sounds crazy I know, but it has worked for me in the past.
    Nov 2002
    Alabama
    I used to get that error message many times, (read errors at address ... , write errors at address ...). I found a good HD defrag and reboot works wonders.
    -D
  11. Member Ziffelpig's Avatar
    May 2003
    Soviet Canuckistan
    It could be your version of TMPGEnc, some versions are pretty buggy. Also what is your source? Has it been uncompressed? Have you tried frameserving? If V-Dub won't frameserve try Avisynth.
    Just shut up and listen dumbass
