Hi,
Recently I took a DVD I burnt to a friends house who has a widescreen Plasma display.
Thinking that it was widescreen complient I was shocked to find it was in 4:3 format with black bars at the top and bottom. My friend had to zoom the plasma display.
I had until this time always believed that I had been configuring TMPGEnc correctly for both 4:3 and 16:9 displays because:
1 - I had set TMPGEnc to 16:9
2 - It looked fine on my 4:3 display (Black bars on top and bottom)
I have read every guide and I am very confused to say the least.
I think the following settings may be correct because the video looks stretched in TMPGEnc but displays correctly on 4:3
Details
GSpot reports the AVI file details
Size : 608x256 (2.38:1) [=19:8]
FPS : 25
NOTE: there are NO black bars on the top or bottom of the AVI
I now set TMPGEnc to MPEG2 with the following settings:
Video Tab
Size : 720 x 576
Aspect Ratio : 16:9 Display
Frame rate : 25 FPS
Advanced Tab
Source aspect Ratio : 4:3 625 Line (PAL)
Video arrange Method : Full screen (keep aspect ratio)
I still have to test this on a 16:9 display but even if it works I do not understand the 2 different aspect ratio settings.
Can anyone help to clarify this problem.
http://www.thedigitalbits.com/articles/anamorphic/anamorphic235demo.html
Not owning a 16:9 WS television I watch my wide screen movies on my 46" 4:3 with the black bars. But even a 16:9 (which i believe is best suited to 1.85:1) will display black on "extra wide" (my words) ratio movies.
Thanks Holistic.
That site seemed to confirm what I am doing is correct.
I should have said in my original post that on the Wide screen Display there was black top and bottom and left and right.
Still not sure what the 2 different aspect ratio settings in TMPGEnc mean however.
Aspect Ratio
By ping182nz7 in forum EditingReplies: 12Last Post: 26th Apr 2010, 13:30 -
No aspect ratio 5/4 in Tmpgenc Xpress
By sychern in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 03:06 -
Tmpgenc xpress Image Resolution & aspect ratio
By sychern in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 08:25 -
16.9 Aspect Ratio with TMPGEnc dvd author 1.6
By GJF in forum Authoring (DVD)Replies: 22Last Post: 24th Jun 2008, 03:57 -
Tmpgenc Express: Aspect ratio problem
By shashidar in forum Video ConversionReplies: 1Last Post: 11th Mar 2008, 18:59
