Hi all.
I have the DVD U2 - Rattle and Hum and would really like to extract the audio as .wav or something for editing and burning later.
The only doubt I have is to extract the audio as wav for Sound Forge to be able to manage the file. I find no way to do this anywhere in Internet.
Someone help me please. I accept links for guides if you have some...
PS: I tried DVD Decryper and could already extract the audio, but I don't know what to do with the .vob file.![]()
The VOB files are multiplex MPEG2 files that contain: video (m2v), audio (ac3 or pcm) and subtitles. More than likely the audio is encoded as ac3 (some concert DVDs do actually use uncompressed PCM, ie wav, audio thou).
Here's how it works:
1. Run smartripper and choose the VTS of interest
2. Click on 'stream processing', click enable stream processing
3. Click on the audio stream of interest, then click 'de-mux'
4. Click run (choose output folder)
This will demux the audio (ac3) file from the VOB stream. You can then convert the ac3 file to wav for editing or burning to a audio CDR:
http://www.doom9.org/audio-guides.htm -
(adding on to Vejita-sama)
5.Use AC3Tool to convert to WAV.
BTW..you can do the same with DVDDecrypter.If you still have the VOB d/l VOBEDIT and open the VOB and select Demux(MPEG & AC3). -
Thanks you all for helping me.
With your tips I could rip and then convert the ac3 file into wav.
It was a very simple process.
I only can't understand what "de-mux" means. What does if happen if I don't select this? What's the difference?
Thanks again. -
Demux simply means you are separating the audio stream from the video stream and creating two distinct files. One audio, and one video.
Originally Posted by Laddydaddy
Thanks.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
Please help, im hopeless and dunno where to begin making dvd from video cli
By wendydoncon in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 10:49 -
Clipping/Distorion in audio - hopeless case?
By gtmb in forum AudioReplies: 0Last Post: 21st Oct 2011, 04:00 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45
