  1. Ive tried making dvds using some of the tutorials but all of them have been out of sync testing them on windvd. I use tmpgenc, ifoedit and dvd moviefactory 2 to create the structure of a dvd but the audio is always out of sync. Any suggestions??
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    A/V sync problems are one of the most asked about topics on this site. There are several ways to fix the problem but usually it is your method that needs to be looked at first. Please give as much detail step by step as possible, including all programs used. It's the only way to get some helpful suggestions.
    Also, is the sync out by a fixed amount throughout, does it go out at a certain point, or does it get progressively worse?
    BTW, please be more informative on your subject line as well.
    Welcome to the forum!
