  1. I have several small avi file sI want to put onto dvd. When I play them or put them into tmpg there are small black cars on both sides of the picture. Even when I select full screen they dont go away. Is there any way to remove these bars?
    The clips are 20 min each. How many should I be putting on each dvd? They are animation.
  2. The captured video might have been recorded off of a satellite signal, which only 704x??? wide. When captured at 720x480 (a resolution many capturing devices record video at), you will see black bars on a side or two.
    You can resize the file with TMPGEnc under something like "clip video".
