Does anyone know if you can include subtitle from the original files (at lease one) to the structure to build a new dvd structure with subtitle? I use version 1.5.13.44 of the TMPGEnc DVD Author software and it does not seem to support subtitle at all.
Thank you
TMGP Author does not support subtitles. The only authoring programs (that I know of) that do are: DVD Maestro, Scenarist, Reel DVD, Adobe Encore and IFOEdit. Of that list only IFOEdit is free.
What some people do as a work around is author the VOB files in IFOEdit, import/load them in TMGP (I think TMPG accepts VOB files I know that DVD Lab does) then author. You'd have to select the subtitles manually with the remote. -
lacali
Say you have 3 titlesets (IFOs, BUPs, VOBs) with multiple audio and subtitle streams and want to use DVD Author. With IFOEdit you can do this:
1) Make a menu with 3 tracks and use very short clips... saves time.
2) Move all the VIDEO_TS (not VTS) files to the folder with the 3 titlesets.
3) Open VIDEO_TS.IFO/VMG_PTT_SRPT and enter the number of chapters for each titleset.
4) Save file and Get VTS sectors.
5) Open each VTS.IFO/VTS_PGCITI/VTS_PGC_1 and add a Post Command (CallSS VMGM) Call VMG title-menu, Resume Cell = 0. Save each file. (menu will return after each movie)
If you want the Play All button to work properly, copy all the post commands (step 5) from each IFO file created with DVD Author to the 3 titleset IFOs. (Use hex copy & paste)
Hope this helps,
Chas
.srt to .subtitle ( from TMPGEnc authoring works 4 )
By shaktiIIIgta in forum User guidesReplies: 5Last Post: 30th May 2022, 08:51 -
Authoring DVD with four subtitle tracks and PCM audio?
By bizzybody in forum Authoring (DVD)Replies: 7Last Post: 28th Feb 2010, 23:17 -
Weird subtitle colors when authoring a DVD
By dexter30 in forum SubtitleReplies: 4Last Post: 22nd Feb 2010, 22:54 -
weird subtitle error during authoring of a DVD
By michcio in forum SubtitleReplies: 2Last Post: 26th Oct 2008, 08:11 -
subtitle timing when converted from srt to .sub (for DVD authoring)
By qknet in forum SubtitleReplies: 4Last Post: 10th Oct 2008, 05:22
