I am very new to this process, so this problem may sound very inferior but i just cant figure it out.
I loaded a avi file into virtual dub so i could split into 2 separate files. However it was encoded with a VBR audio format which may be the source of the problem. Upon the split i played one of the files in powerdvd and burnt the same file to disc. When i played them there is a audio problem where the sound is around 5 seconds behind the video, as the film progresses the audio lags further and further behind. This problem is present on both the disc and on powerdvd, so i must assume it is a problem with virtualdub. Can anyone help me on what to do to correct this problem.
Puffyeye
Here is a guide.
https://www.videohelp.com/forum/userguides/140540.php
Welcome to the forum
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
Subtitles - progressive sync and incompatibility (srt and sup)
By sooojaded in forum SubtitleReplies: 3Last Post: 7th Feb 2012, 15:59 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 16:19 -
XVID4PSP: VOB to MPEG2 (hard subs) progressive av sync issue
By txporter in forum DVD RippingReplies: 1Last Post: 24th Feb 2009, 12:48 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 07:31
