any special program to do this os x? in 9 i could just copy the .dat file over add the .mpg and it worked, but osx won't let me copy it.
pants on, pants off, pants the floor.
already been covered.
VCDCopyX
http://www.ns-software.com/VCDCopyX/ -
Or you can use my fav
vcdtoolsX
just open the app, go to the vcdXrip button and choose your .bin and push start.
the mpeg file will be in the same folder your .bin is in
enjoy!
(if you dont have a .bin but have .img or some other form of disk image you just rename to .bin)
If you have the CD itself, just use toast to save it as a disk image to your HD, then remame from .toast to .bin, then run the app
you can get it from versiontracker.com -
Ok I'm having problems with this. I used toast and created a .toast file from my VCD disk. I renamed the .toast .bin. I went into vcdtoolsx and clicked the first button. I selected the .bin file and a place for the output. It ran for like 8 hours and I stopped it. How long does it take?
I see nothing about your comptuer specs in yoru profile
what type of comptuer do you have?
for me it takes only a few min.
8 hours seems excessively long.
did you check to see if you got any file saved as your destination? -
I'm using a 12" Powerbook G4 867Mhz with 640 MB of RAM.
Never mind. False alarm. The funny thing was when I opened VCDtoolsX the vcdXrip and vcdXgen did not have icons. The box was blank. I quit VCDtoolsX and relaunched it and the icons were there. I tried it again and it worked. -
sometimes it happens for me too.. but not as you mentioned
for me, you click start and nothing happens
you quit, reopen and reset the paths, and that time it works...
ah well... 8)
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 21:49 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 21st Aug 2010, 00:01 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 14:13 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 16:00 -
mpeg1-(VCD) to DVD w subtitles - possible?? Help please!
By nbarzgar in forum Authoring (DVD)Replies: 25Last Post: 28th Jun 2007, 19:30
