  1. I recently purchased a Toshiba sd2700 dvd player. I just burned a xvcd and vcd using different types of recordable cds. I have used Sony CDRW, Gigastorage, Professioanl Memeorex, and a few other brands. Everytime i play the movie it stops for a second a plays for a second. What should i do?? Is it the CDs, Nero, or my DVD Player?
  2. Member adam's Avatar
    Sep 2000
    If you want to respond to this question please do it here
    Jun 2001
    Mr CDR
    To find out whether it is the problem of the media or the way of burning, just copy a commercial VCD to the CD-RW and play it in your player. It it works then it is the burning problem. If it dosn't work then change another brand CD-RW.
